Now available in a download location near you:
3.2.4 has several changes:
The pin palette may now be made visible again after it has been hidden.
The installer will optionally clear settings - this was added to fix a problem with new versions of Curvemeister crashing because of old window settings retained in the registry.
The installer recognizes CS5 and Elements 8 (please note the beta currently only supports the full (Photoshop and Elements) version of Curvemeister.
A registry related error in beta 3.2.3 that affected Windows XP and Windows 2000 has been fixed.
32 bit 3.2.4 available
This one has an installation bug which can only be described with a screenshot:
It's just dawned on me - a single hyphen is used to indicate "no company," as used for individual users like me. :)
I'm not sure what the dialog is trying to say, but I think fleshing it out a bit might help!
I have windows 7 pro- 32 bit. CS5. CM 3.2.4
Still have problems with CMYK.
Screenshot 1 is after opening an image in RGB mode.
Screenshot 2 is same image converted to CMYK. Note not wg cmyk.
Screenshot 3 is same image converted back to RGB. Note it is now wg cmyk.
No big deal, just a little aggravating.
- tiger-ss1-jpg (82.83 KiB) Viewed 56474 times
- tiger-ss2-jpg (83.13 KiB) Viewed 56474 times
- tiger-ss3-jpg (83.4 KiB) Viewed 56474 times
Hi Steve,
This is actually by design, sorry. The reason I did it this way was because wgCMYK was designed as a lossless way to do CMYK editing on an RGB image. Since you can already edit a CMYK image in CMYK, I didn't see a benefit to providing wgCMYK.
Historically, before people were thinking about Lab much, Curvemeister started out as a way to edit RGB images in CMYK mode, so only the wgCMYK mode was available - if you can imagine that!
