Crash Bug 64 Bit
Postby ggroess » Fri Jan 22, 2010 4:21 am
Tried to open a ACV file from the desktop in CM64 and hard crashed the CM plugin.  repeatable...
It does hurt PS as well I cannot go forward from the crash..I have to shut down PS and I get a windows error upon exit.
Everything recovers when I restart PS just cannot load an ACV...
The dump files are attached as zipped...
Postby -default » Fri Jan 22, 2010 6:19 am
Thanks for the crash dump, Greg.
I'd swear I fixed this one not long ago, but I guess some bugs are so nice I have to fix them twice.
Postby ggroess » Fri Jan 22, 2010 2:54 pm
I know you fixed it in 32 bits....
Postby -default » Fri Jan 22, 2010 9:58 pm
My mistake entirely, of course.  When I heard that file loading was working, I didn't stop to verify that it was working in both 32 and 64 bits.
Postby ggroess » Fri Jan 22, 2010 10:21 pm
Purely accidental I assure you...LOL
Is 3.0.19 the fix for this?? or did we hit the magical 20....
Postby -default » Sat Jan 23, 2010 12:15 am
There is a 20 on the way that includes the redistributables as part of the installer, and a newer version of the crash reporter - 19 is the one that fixes the file loading crash.
Postby ggroess » Tue Feb 23, 2010 2:19 am
This one appears to be squashed...at least on my system..
Users browsing this forum: Google [Bot] and 5 guests
