Baltit Fort
Postby mikemeister_admin » Fri Jan 22, 2010 3:32 am
This the original version of a shot of Baltit Fort, on the Karakoram Highway between China and north Pakistan, taken last May.  I thought  it might make an interesting picture, but I've made several unsatisfactory (pre CM) attempts so far.  I will try my newly acquired CM101 skills on it shortly; but if anyone else feels like taking a swing they will be very welcome.
Richard
baltit-fort-jpg
baltit-fort-jpg (999 Bytes) Viewed 36461 times
Postby ggroess » Fri Jan 22, 2010 3:59 am
What perfectly delightful image....Thanks for letting me play...
I encourage everyone to take a swing at this image there is a lot of small issues that add up to a fairly complex correction...it pulls from many different areas of both PS and CM.  I will tell you that I used CM for 95% of my correction but you can go anywhere you want...Used a Highpass filter for sharpening.
baltit-fort_gg-jpg
baltit-fort_gg-jpg (210.31 KiB) Viewed 36461 times
Postby mikemeister_admin » Sat Jan 23, 2010 5:45 pm
Until I could fix up the sky,I'd make the picture about the fort on the hill.GregM
Second image is an idea for  an image complete with sky.
baltit-fort-copy-jpg
baltit-fort-copy-jpg (288.92 KiB) Viewed 36461 times
baltit-long-copy-jpg
baltit-long-copy-jpg (289.98 KiB) Viewed 36461 times
Postby ggroess » Sat Jan 23, 2010 6:21 pm
I thought the mountains had a lot more color that was able to be brought out by increasing the color contrast and making the yellows more important.  It also helped the haze in the middle of the image to pull that out more...
Your thoughts??
Postby mikemeister_admin » Sat Jan 23, 2010 10:39 pm
Well,I'll be working on this one a bit in the coming months.GregM
Postby ggroess » Sun Jan 24, 2010 12:21 am
I thought you might....Try a mask for the foreground and see if you can save some of the sky...
G
