Tiger
Tried using the paw and a shadow point in the tree bark on the left. Used the lighter color rock in the back right for a neutral. I liked the colors better in RGB as the looked a little more natural. Using contrast pinning in a second curve with a large sample size (45) to bring out the stripes a bit.
- tiger-jpg-2 (999 Bytes) Viewed 25464 times
- 2008-01-30_142354_02-jpg-rgb-acv
- 2008-01-30_142354_02-jpg-rgb2-acv
He looks very nice...
Did you try a LAB pass for color to just bump it a bit?? I know you did this in RGB and the color looks nice...I tried saturating it just a bit more just to see what happens. The yellow fur is improved a bit by setting the saturation slider to 1.15 you might have to hand type it into the field to get it to go there...
Give it a try..The image looks fine as is...I just try to push it a bit harder....
