Kind of took the directions literally and tried to make the text black and paper white while somewhat disregarding the image. Used two curves in the "L" channel after setting the endpoints with the Histogram.
Berkeley Voice
- berkeley_voicefix-jpg (999 Bytes) Viewed 41872 times
- berkeley_voice-jpg-lab-acv
- berkeley_voice-psd-lab2-acv
Ahhh..good to have the tools working again...
OK Here we go...
Instead of two curves that at times appear to be competing how about this....See attached shot.
This is one image where the histogram can help you a bit but not as much as the threshold adjustments. If you look at the image I have 3 areas I am most concerned about..the highlight details, the shadow details, and the dots in the picture.
The highlights I want to keep as much information in the image as I possibly can. Remember the prints you might have created will need as much highlight and shadow details as possible. I use the threshold to help me not clip the highlights.
Shadows I wanted them to be dark and saturated but not at the cost of the dots in the shadows of the image. making the s curve helps the shadows without hurting the image shadows too much...You certainly can argue that I did some damage there but I think the scaled down image does it more harm than I did.
The dots....I know I have to tkkep as many as possible in this image. Usually you want to be rid of them and I don't mind losing some here but when the dot loss = details in the image It means I want to keep them...I placed the hue clocks to check the skin tones and see if I needed an adjustment there but they look acceptable for this type of image.
I went on to saturate it a bit more by sliding the saturation slider up to 1.25 It helps the overall image....mine shows 1.00 because after the screen shot I changed my mind...
OK Here we go...
- screenshot001-jpg-96 (284.78 KiB) Viewed 41872 times
