I cant get this shot right - can you
Postby mikemeister_admin » Thu Jan 07, 2010 8:43 pm
I just love this image - mystery how they were made .
But I can not adjust it to my liking - Help! can you?
dsc_6893snowballs-jpg
dsc_6893snowballs-jpg (999 Bytes) Viewed 9492 times
Alex314
Postby Alex314 » Thu Jan 07, 2010 9:06 pm
Hi,
Isn't it just a matter of applying the correct white balance? I tried that. But I agree that the contrast doesn't seem right...
Regards, Alex
dsc_6893snowballs-2-jpg
dsc_6893snowballs-2-jpg (153.86 KiB) Viewed 9492 times
Alex314
Postby Alex314 » Thu Jan 07, 2010 9:14 pm
This one maybe better, what do you think?
Alex
dsc_6893snowballs3-jpg
dsc_6893snowballs3-jpg (143.9 KiB) Viewed 9492 times
Postby ggroess » Thu Jan 07, 2010 9:21 pm
Zog,
Once again into the breach eh?
OK I went with a high key so the darkest shadow should not be below 50% but then I hit the it just doesn't look right point and started twiddling
I went with a BTN correction and bumped the middle tones a bit to make the contrast range look right...
shot1-jpg-92
shot1-jpg-92 (247.43 KiB) Viewed 9492 times
dsc_6893snowballs_gg-jpg
dsc_6893snowballs_gg-jpg (283.43 KiB) Viewed 9492 times
Postby mikemeister_admin » Thu Jan 07, 2010 11:40 pm
Nope.GregM
Later I took first image(sharpening and desat)and did a select color range,invert mask then hue saturation set to cyanotype.GJM
dsc_6893snowballs-copy-jpg
dsc_6893snowballs-copy-jpg (270.86 KiB) Viewed 9492 times
dsc_6893snowballs-copy-2-jpg
dsc_6893snowballs-copy-2-jpg (229.14 KiB) Viewed 9492 times
