Would love to see what you can do with this Woodpecker shot I took this morning.
Who can make the Woodpecker sing?
The slight discoloation under the beak is intentional.GregM
- woodpecker-copy-jpg (233.85 KiB) Viewed 12345 times
- woodpecker-copy-hsb-acv
- (70 Bytes) Downloaded 738 times
There are multiple things going on...
The bird has been corrected BTN in the RGB space. It was tough to choose a neutral...
The saturation was boosted in LAB.
The background was changed using a LAB trick to replace the colors.
I blurred the A and B channels a bit in LAB to reduce the back ground noise.
I sharpened using USM and a copy of the same mask used for the background color change.
