St Vitus Spire
Postby mikemeister_admin » Fri Jan 01, 2010 11:22 pm
I used RGB to get the blue in the sky and the green in the copper,then an s curve in Lab for some detail to the left panel of the spire.GregM
st-vitus-spire-jpg
st-vitus-spire-jpg (999 Bytes) Viewed 24679 times
2005-08-31-010943-copy-rgb-acv
2005-08-31-010943-copy-lab-acv
st-vitus2-jpg
st-vitus2-jpg (999 Bytes) Viewed 24679 times
Postby ggroess » Fri Jan 01, 2010 11:32 pm
Kinda heavy in the shadows...were you going for a different feel?
Postby mikemeister_admin » Sat Jan 02, 2010 1:08 am
I found the shadow detail  and surface grit on the copper sheets were closely linked.I might try another pass to separate them.GregM
Above I posted the picture minus the contrast curve but a curve in the k channel of CMY and a saturation boost.GregM
