Lab duck
Postby mikemeister_admin » Mon Dec 14, 2009 4:56 pm
I've used the wizard a little in the past, so it wasn't too difficult to get basic improvements in both Lab and RGB.  However I struggled to get rid of a green cast in Lab.  In this case, RGB was easier.
2007-01-23_145313-duckrg-lab-jpg
2007-01-23_145313-duckrg-lab-jpg (999 Bytes) Viewed 5071 times
Postby ggroess » Mon Dec 14, 2009 5:56 pm
Did you use the leg band as a neutral??
Try finding one on the leg band and see if the green falls away...
