I thought this might be an interesting shot to have a bash at.
The figures in the stone work on this stained glass window are getting a little lost - can you bring them out a bit?
I need some detail in this snapshot I took today
One direction,a contrast pin.GregM
Lost some detail in the clear panes and stone color is iffy.
Just below the clear vase in the left hand panel is B/W tree trunk with a sprout crossing it.I would like it to be noticible.
- dscn2254-copy-jpg (263.58 KiB) Viewed 11151 times
- dscn2254-copy2-copy-jpg (265.06 KiB) Viewed 11151 times
Try using the contrast pins in the color channels to move both points at the same time and see if you can increase color contrast and move the color in a direction you like better. Once you set the contrast pin is should be active in all the channels and you can move the points together in any direction.
I use this frequently...
