Pinning-presets causes crash
ulfstr
Postby ulfstr » Wed Dec 02, 2009 2:39 pm
Hi!
Posted at "Pinning" before but this is maybe the right place. Anyway.
When I copy SHN Skin Tones.txt and AmandaHerbert's Skin Tones.txt in the swatches folder in my W7-64 machine with PSCS4-64 and CM3.0.16-64bit and then open PS and CM it all crashes.
Does these pinningpresets not work in 64 bit, or is it a bug?
Regards Ulf
Postby -default » Wed Dec 02, 2009 8:22 pm
It's definitely a bug!  Thanks for documenting the file names.  I'll see if I can recreate the problem and come up with a solution, or a work-around.
