JoAnn's A B Channels
joann
Postby joann » Tue Nov 10, 2009 11:20 pm
I watched the video about 4 time and took notes. Hopefully, I'm close on this one.
JoAnn H
abchannels-1web-jpg
abchannels-1web-jpg (999 Bytes) Viewed 20782 times
abchannels-1-jpg-lab-acv
screen-shot-abchannels-1curvesweb-jpg
screen-shot-abchannels-1curvesweb-jpg (999 Bytes) Viewed 20782 times
Postby ggroess » Wed Nov 11, 2009 2:17 am
There should be more color variation in the greens....
When you go to set the contrast pin in the  green areas set your sample size to say 11 and then select the contrast pin in the greens.
Remember to set it back when you are done.
The large sample size will give you a bigger contrast pin area to work with in the correction.
