Temple figures
I selected the bottom half of the image then used k channel in CYMk to shape contrast then pulled down the CMY curves an equal amount.Inverted the selection and applied the same correction to the top.A slight lizzard tail in the B channel of HDB brightened the top a bit more.The idea was to keep the gold looking metallic not buttery.GregM
- 2007-11-20_223925-copy-jpg-2 (999 Bytes) Viewed 20109 times
