I did the Lab saturation with lightness mask. I didn't care for the HSB s curve. I thought I'd try the wizard and I like it best of all.
JoAnn H
Tiapei Graffi
- tiapie-graffiti-jpg-lab-acv
- tiapie-graffit-wizard-jpg (999 Bytes) Viewed 7151 times
- tiapei-graffi-lab-sat-web-jpg (999 Bytes) Viewed 7151 times
The wizard does give a general overall good response...but...there is the control issue...if you do not use a mask and just use the saturation slider there are areas of the image that get over saturated. They should be controlled and that is where the mask comes in...
These look pretty good overall I think the upper one is too saturated...the trees, the cab...they all give it away...
Now that I look at it I agree with you the mask in LAB is better.
JoAnn H
JoAnn H
Users browsing this forum: No registered users and 67 guests
