Here's my tassels.
JoAnn H
JoAnn's Tassels
- tassels-copy-lab-acv
- screen-shot-tassel-curves-web-jpg (999 Bytes) Viewed 15419 times
- 1-tasselsred-to-black-web-jpg (999 Bytes) Viewed 15419 times
Joann,
The shadows give this one away...
Julie had the same problem...
See this posting for some suggestions...
http://www.curvemeister.com/forum/index.php/topic,2828.0.html
Here's my 2nd try. I still see red in the shadows. I'm going to have to work fast. I've lost a lot of time.
JoAnn H
JoAnn H
Joann,
- 2nd-trytassels-jpg (120.89 KiB) Viewed 15419 times
- tassels-lab-acv
- (54 Bytes) Downloaded 890 times
OK is this better. I think all the red is gone from the shadows.
JoAnn H
You can do this interactively...Select the mask channel and then click on "all" up by the mask Icon. When you adjust the mask curve you should see the effect on the image...
- 3rd-trytassels-jpg (162.59 KiB) Viewed 15419 times
Users browsing this forum: No registered users and 70 guests
