wgCMYk image
I was trying some new things this afternoon and I thought I might as well try an image in wgCMYk.I used the k channel to shape the overall contrast,then slid the color channels right an equal amount like a saturation slider.Pulling down the cyan curve gave the sky color and made the clouds pop out.The whites in this image should be almost pure with no indication of cyan.GregM
- lil-tug-orig-jpg (999 Bytes) Viewed 7806 times
- lil-tug-wgcmyk-jpg (999 Bytes) Viewed 7806 times
- wgcmyk-image-jpg (999 Bytes) Viewed 7806 times
What a wonderful image...Try opening the shadows in the areas highlighted by the "HiLite Curve" Feature. Look at the K channel grid and you will see the range of the shadows shown.
Try it but if you still don't like it that's cool too...Awesome image...really....
- screenshot001-jpg-107 (287.48 KiB) Viewed 7806 times
Users browsing this forum: No registered users and 72 guests
