Red vs Yellow car
joann
Postby joann » Wed Oct 28, 2009 8:13 pm
I read your hint about HSB and tried it. I got a yellow car with spots on it. How do you fix that?
JoAnn H
cari-love-curves-jpg-hsb-acv
capture_redvsyello-web-jpg
capture_redvsyello-web-jpg (999 Bytes) Viewed 5308 times
cari-love-curvesweb-jpg
cari-love-curvesweb-jpg (999 Bytes) Viewed 5308 times
Postby ggroess » Wed Oct 28, 2009 9:32 pm
Flatten the hue line to horizontal completely select both ends of the line and move it up or down until you hit the yellow you want for the car...many many hues are possible you might just get to like this one....ignore the grass at first...
Then...Adjust the curve line only where you see the worm when you place the mouse over the grass...
