JoAnn's purple dog
joann
Postby joann » Tue Oct 27, 2009 1:30 am
Greg, I figured out how to "select" the curve lines so they would move together. I click on the top, held the shift key down and clicked on the bottom curve line. Then both ends moved together.
Here's my purple down. Neat way to make a mask.
JoAnn H
purple-dog-web-jpg
purple-dog-web-jpg (999 Bytes) Viewed 9001 times
Postby ggroess » Tue Oct 27, 2009 2:18 am
Did you blur the mask any??  It looks like the edges are a bit off in the inside of his back legs...
It is a great way to make a fast mask...and you have access to all the channels at the same time...something the color theory group is trying to figure out how to do today in the postings....
joann
Postby joann » Tue Oct 27, 2009 2:57 pm
You see everything....lol
I didn't blur the mask but after I was finished I cleaned up the grass so the photo is blurred.
JoAnn H
Postby ggroess » Tue Oct 27, 2009 3:35 pm
My omnipotence has boundaries...I cannot read my wife's mind for instance....
;D
joann
Postby joann » Tue Oct 27, 2009 4:02 pm
Oh, my gosh! My laugh for the day.....
JoAnn H
;D
