JoAnn's Cleaning up Berkeley....
joann
Postby joann » Mon Oct 26, 2009 4:44 pm
After last weeks Berkeley Drummers just the name struck fear in my heart.
I went back and forth between lab and rgb that I didn't save all the ACV files.
Just the finished photo. I tried to keep the paper neutral and the skin tone within 12:00 & 1:00. I'm thinking it looks a little over saturated but I didn't know how to fix it.
JoAnn H
10-26berkeley_voiceweb-jpg
10-26berkeley_voiceweb-jpg (999 Bytes) Viewed 6628 times
Postby ggroess » Mon Oct 26, 2009 6:19 pm
Well If you feel you need to adjust the saturation you have two different ways to do that.....
LAB saturation slider works both ways..it can de-saturate the image as well as saturate it..
There is also a S channel in HSB....You could adjust it there if you need to....
joann
Postby joann » Tue Oct 27, 2009 2:51 pm
Thanks Greg. I will lower the saturation just a smidge.
JoAnn H
