biscuits
Postby imported_julie » Mon Oct 19, 2009 3:43 am
first of all i thought that the colour change was fairly insignificant, but.. i decided to try to get rid of it. I think maybe it is the colour of the biscuits because it is stronger in the shadowed areas of the plate that in the parts with no shadow. Maybe it is the wellow carpet reflected somehow.
Anyway I tried a few ways to do it but I thought the simplest gave the best result. I used neutral and thresholding and saturation. I added a little contrast but not much and finished of with sharpening in elements. I use a plug in called neat image.
I have thought I should try cmyk but I'm a bit stressed about the pins and acv file to even think of tackling that monster again right now. Maybe tomorrow.
biscuitslab-jpg
biscuitslab-jpg (999 Bytes) Viewed 6628 times
biscuitslabweb-jpg
biscuitslabweb-jpg (999 Bytes) Viewed 6628 times
Postby ggroess » Mon Oct 19, 2009 8:55 pm
I think you have done A fine job of reducing the color in the plate...There have been many theories about the color but in the end it is a matter fo taste and curve control...you did a fine job...
