Pinning Skin Tones in CM - Advanced Workflow
Postby ggroess » Sat Oct 17, 2009 2:31 pm
As I work on skin tones in CM one of the biggest hurdles is knowing what "Skin Pin" to set.  I have created a few resources for you to use and build upon.
Lastly is the work flow...
joann
Postby joann » Sun Oct 18, 2009 1:31 am
Thank you for all the extra help. I'm going to need it. lol
JoAnn H
Postby mikemeister_admin » Sun Oct 18, 2009 2:26 am
Greg,do you have a .jpg of the infant before?GregM
Postby ggroess » Sun Oct 18, 2009 2:23 pm
I'll have to check...that should be out on the server...
Postby ggroess » Mon Oct 19, 2009 9:41 pm
Wow this took a while to find....
Here is the original image granted to us by ganna....
002-jpg-2
002-jpg-2 (198.47 KiB) Viewed 12210 times
Postby mikemeister_admin » Mon Oct 19, 2009 11:10 pm
Thanks,GJM
Postby mikemeister_admin » Thu Oct 22, 2009 1:32 pm
Greg,how do I get the gradient from the grad editor to the new doc I created?Not really a computer person.GregM
Postby ggroess » Thu Oct 22, 2009 8:26 pm
The gradient is a separate image...you just sample it for the Pins.  You need not bring it into the image...
But you did just spark an idea...I'll get back to you if it works....
