julie wreath
Postby imported_julie » Fri Oct 16, 2009 7:53 pm
I think I got rid of the shadow but without the hint I would have had no idea. I think the colours look a bit 'thin'. I did try to move things but mostly it just got worse.
I tried to use sample points to check colours but they did not show anything and the sqare box above the windows that normally indicates colours was not working either. Do I have a problem?
oops wrong image, cant find the screen for this which is a shame
wreathscreen-jpg
wreathscreen-jpg (999 Bytes) Viewed 13544 times
wreathweek2-jpg
wreathweek2-jpg (999 Bytes) Viewed 13544 times
Postby mikemeister_admin » Fri Oct 16, 2009 8:02 pm
cymyk box. I think that happens when you're working on an adjustment layer.I merge down to a background layer,took me months to figure that out.GregM.
Postby imported_julie » Fri Oct 16, 2009 10:52 pm
thanks, I may never have worked that out
Postby ggroess » Sat Oct 17, 2009 1:57 pm
Well done...CMYK usually drives people nuts..have you used it before??
The shadows look good, the color separation in the magenta/reds is very good.  The cyan / blue could be stronger but is most certainly acceptable.
Postby imported_julie » Sat Oct 17, 2009 11:28 pm
never used it before and I would be happy not to do it again. Still it was very interesting to watch that shadow go.
Postby ggroess » Sun Oct 18, 2009 12:24 am
Keep CMYK in mind..It has proven to be very useful even if you are not going to press...There are things in CMYK that can solve very tricky problems.
We also need the separate channels for masking and color enhancement.
