JoAnn's Pumpkin Example 3
joann
Postby joann » Tue Oct 13, 2009 3:28 pm
Looks like I forgot to post this one.
JoAnn H
pumpkins-example-3-jpg-hsb-acv
pumpkins-example-3web-jpg
pumpkins-example-3web-jpg (999 Bytes) Viewed 11722 times
pumpkins-screenshot-jpg-2
pumpkins-screenshot-jpg-2 (999 Bytes) Viewed 11722 times
Postby ggroess » Wed Oct 14, 2009 1:33 am
Joann,
On this one you need to start in the Saturation space and play around a bit the Idea is to make the pumpkins look rounder by adjusting the saturation.  When you desaturate the image too much the pumpkins look white and sickly...when you kick it just right you can get tones of color and shape...
Start in Saturation..then adjust the brightness slowly and lastly adjust the hue to keep them from turning too yellow in spots....
I'll post my version for you to look at but remember that you can probably surpass me on this one...
2007-10-15_172735_gg-jpg
2007-10-15_172735_gg-jpg (280.39 KiB) Viewed 11722 times
joann
Postby joann » Wed Oct 14, 2009 8:36 pm
Here's my 2nd try at the pumpkins. Hopefully I've done better on this try.
Tell me about the red curve. I know it is some kind of guard but I don't know the meaning. I seem to get those pretty often and I've learned I have to back off to get rid of it.
JoAnn H
2nd-try-pumpkins-example-3-jpg-hsb-acv
(114 Bytes) Downloaded 809 times
2nd-try-pumpkins-screenshot-jpg
2nd-try-pumpkins-screenshot-jpg (92.07 KiB) Viewed 11722 times
2nd-trypumpkins-example-3web-jpg
2nd-trypumpkins-example-3web-jpg (92.5 KiB) Viewed 11722 times
Postby ggroess » Wed Oct 14, 2009 9:24 pm
The red curve is called "Curve Guard" it is Curvemeister's way of telling you that the curve you have created in the color space you are working is not "valid"  that it will create colors that have values out of the gamut for the color space you are working in.  For instance there are yellows in LAB that will not even display on the monitor but the color space has a value for them.
Curve Guard helps by giving you visual feedback on that event so you can avoid it...In PS you would have to know what the limits of the specific color space are in order to avoid this problem.
BTW smaller hue and brightness adjustments go a lot further in HSB...
joann
Postby joann » Wed Oct 14, 2009 10:04 pm
Greg, here's my 4th try on the pumpkins.....I hope you are not getting sick of me.
I think this looks better but I've stared at them so long I don't know.
One thing that is driving me nuts is the pink cast that I can see in the highlights. Also, in the upper left corner there is a pumpkin that has a lavendar cast in the highlight.
Would you mind sending me your ACV file?
JoAnn H
4th-trypumpkins-example-3-jpg-hsb-acv
(126 Bytes) Downloaded 727 times
screenshot-4th-try-pumpkin-exam3web-jpg
screenshot-4th-try-pumpkin-exam3web-jpg (145.54 KiB) Viewed 11722 times
4th-trypumpkins-example-3-jpg (147.96 KiB) Viewed 11722 times
Postby ggroess » Wed Oct 14, 2009 10:21 pm
sure...here ya go...
2007-10-15_172735-jpg-hsb-acv
(106 Bytes) Downloaded 708 times
