julie pumpkin
Postby imported_julie » Tue Oct 13, 2009 9:14 am
getting ready for work and had some spare time to do this. I have done it before reading the notes for second week so maybe its not right. I will be able to read all the notes in my break tonight and do some more in a couple of days.
I feel ok about this one. It was hard not to go over board. I also found I lost some green and had to back off on the saturation channel a little. Anyway looking forward to hearing where I could have gone. i did add al bit of sharpening in elements
pumpkinscreen-jpg
pumpkinscreen-jpg (999 Bytes) Viewed 5862 times
hsb1pumpkinweek2-jpg
hsb1pumpkinweek2-jpg (999 Bytes) Viewed 5862 times
Postby ggroess » Wed Oct 14, 2009 1:20 am
Julie when you go to far with this image in HSB you get the mottled look you are seeing in the skins and the greens go away...
Try to be a bit more subtle.  The saturation should not suffer for the form...there is a balance in there...
