JoAnn's Merry go round
joann
Postby joann » Mon Oct 12, 2009 1:47 am
I agree with Julie. This was very difficult. I didn't do anything additional in Photoshop.
I've asked the question about how to determine where to put the internal points. I pretty much guessed at where to put them. Is there a scientific method??
JoAnn H
merry-go-round-example-1-jpg-lab-acv
merry-go-round-exampleweblab-1-jpg
merry-go-round-exampleweblab-1-jpg (999 Bytes) Viewed 5884 times
merry-go-round-example-1-jpg-rgb-acv
merry-go-round-example-1webrgb-jpg
merry-go-round-example-1webrgb-jpg (999 Bytes) Viewed 5884 times
Postby ggroess » Mon Oct 12, 2009 2:37 am
Actually Joann you are pretty close...The Curve is too close to the shadow sides.  If you move the middle of the curve "up" Closer to center... a bit it will get a lot better...
BTW this is a really good image for LAB....try it there as well.
