Merry Go Round
Postby mikemeister_admin » Wed Oct 07, 2009 4:21 pm
Took a new tack for this image,but spent a lot of time putting things in and taking things out.GregM
2007-02-12_122115-merrygoround-copy-2-jpg
2007-02-12_122115-merrygoround-copy-2-jpg (999 Bytes) Viewed 8613 times
Postby ggroess » Wed Oct 07, 2009 6:39 pm
At first I thought it was too red...I even went to correct it...but then I found it was really a loss of "richness"  for lack of a better term...It seemed flat in some way...Again I was not able to quantify it...
The skin tones were solid, the horses are neutral, you have opened the shadows.  and yet....
So...Try this ACV on top of your image as posted.  I thought it added a richness to the image.
2007-02-12_122115-merrygoround-copy-2-jpg-wgcmyk-acv
(54 Bytes) Downloaded 699 times
Postby mikemeister_admin » Wed Oct 07, 2009 7:04 pm
You're right,I tried to use PSE's shad/high to balance the upper and lower levels of the ride but it sucked some content from the image and I chased my tail trying to get it back.GJM
Below with Greg's correction
2007-02-12_122115-merrygoround-copy-3-jpg
2007-02-12_122115-merrygoround-copy-3-jpg (278.05 KiB) Viewed 8613 times
Postby ggroess » Wed Oct 07, 2009 8:21 pm
hmmm...all things being equal... Adobe must access the K channel or the L channel to smack the image during the Shadow / Highlight filters application.
I bet you could recover the tonality by not taking such a big bite in S/H in the first place.  maybe it's the levels setting...
