I didn't save the curves on these. Do you want them? On the bubbles I used the wizard.
JoAnn H
JoAnn's Examples 1,2 & 3 Week One
Don't forget that Black and white can also be considered neutrals. It is a sometimes risky move to use them but they should be neutral if they are truly black or truly white. And Yes the second version of the ball is much better than the first.
I need not see the curves for the numbers drill. I can tell you got the idea by the looks of the numbers...
