ex 3
Tough image,the foreground pixilates very easily.I opened a layer set to screen then did shadow,etc in RGB followed by sharpening.I used darken highlights in PSE to add some contast to upper sufaces of balls. I wanted detail to the pipe and the reflected images in the balls.The sharpening I used gave a Monty Pythonesque jump between the last row of balls and the water,it looks almost photoshopped!GregM
- c01s01-example3-copy-jpg (999 Bytes) Viewed 8193 times
