I found this image very interesting because of the cast under the nose - simple (?) to remove before adding a touch of colour.
The statue was on a lawn and thus the reflection from the grass on a sunny day added the cast
Simple colour cast
First I used the magic wand to mask the area with the cast.Then to RGB for a shadow,highlight,neutral.Then a new mask for the disc of the nose and a shot of saturation boost in Lab.Last a bit of adjust sharpness.GregM (I can think of a further step ,but I don't know if I need it)OK,I included a acv file that cuts back some blue,but I see no difference?
- dsc_5145statue-copy-2-jpg (235.96 KiB) Viewed 6016 times
- statue-mask-jpg (212.9 KiB) Viewed 6016 times
- statue-shn-jpg (209.75 KiB) Viewed 6016 times
- statue-blue-removal-jpg (236.73 KiB) Viewed 6016 times
