How to post images to the forum.
Postby ggroess » Mon Sep 28, 2009 1:43 pm
Everyone,
  • Please remember to re-size your images to fit under the 300kb limit per image.
  • If you are new to image re-sizing you can use the PS or PSE "save for web" command under the "file" menu to help you re-size the image.  You might want to keep the overall image size to 1024X1024 as upper limits for both horizontal and vertical sizes.  Just set the quality value to give you an Image that is less than 300kb.
  • You might want to look into a freeware printscreen program.  I use Gadwin Printscreen
http://www.gadwin.com/printscreen/ version 4.3 is free. This will help you capture screens that include the curves windows and to help us work with you on your images.
    greg001-jpg-10
    greg001-jpg-10 (999 Bytes) Viewed 8322 times
    greg002-jpg-10
    greg002-jpg-10 (999 Bytes) Viewed 8322 times
    joann
    Postby joann » Mon Oct 05, 2009 9:27 pm
    I have a topic Joann's 1st week materials....I would like to send you the duck and another example. I don't know how to start a new message. Could you help me with that.
    Thanks,
    JoAnn H
    Postby ggroess » Mon Oct 05, 2009 10:22 pm
    not a problem...
    At the main class forum page you will see some links at the top and bottom of the page click new topic and start typing....
    screenshot001-jpg-127
    screenshot001-jpg-127 (161.34 KiB) Viewed 8322 times
