Taipei Graffiti
Postby mikemeister_admin » Wed Jul 29, 2009 5:17 am
Not sure if I got the colors right on this one and overshot my L adjustment.  Tried to correct it back but not entirely successfully.  The color issue is a curious one.  My hue clocks check out but there is a signficant color shift in the graffiti.  I'm not sure if the new colors are the accurate ones or I went wrong somewhere.
2007-11-19_175158_edited6_downsized-jpg
2007-11-19_175158_edited6_downsized-jpg (999 Bytes) Viewed 33404 times
Postby mikemeister_admin » Wed Jul 29, 2009 11:47 pm
Brian,you brought out the colors on the wall and kept the texture.The colors going into the distance are nice(there's a bit of green back by the guy in the white shirt that's a bit radioactive,but that's a quibble)The sidewalk is neutral but they may point out color cast on the yellow car!Nice job.GregM,the other Greg.
Postby mikemeister_admin » Thu Jul 30, 2009 4:48 am
Thanks Greg,  I kept getting blooms of yellow on the sidewalk that were hard to control at the same time that  I was trying to boost the saturation of the graffitti and I just couldn't get it masked out with any channel in CM.  I think in trying to control that yellow I might have color shifted the graffiti a bit (and even the sidewalk doesn't look entirely right to me).  I didn't notice it until I looked back at the original  I might try this as a "do over" and see if I can do a little better.
Postby ggroess » Fri Jul 31, 2009 12:27 am
Brian,
The greens certainly are over the top...did you use the masking features for this one??  everything else looks ok.  The greens are way out there.
Postby mikemeister_admin » Fri Jul 31, 2009 4:33 am
Here is my "do over" in three images.  The first is the original correction without the saturation boost. In the second I masked in Photoshop and then saturated.  The third is a mask created in CM (not sure which channel I finally settled on).
2007-11-19_175158_edited7_downsized-jpg
2007-11-19_175158_edited7_downsized-jpg (278.42 KiB) Viewed 33404 times
2007-11-19_175158_edited8_downsized-jpg
2007-11-19_175158_edited8_downsized-jpg (245.36 KiB) Viewed 33404 times
2007-11-19_175158_edited9_downsized-jpg
2007-11-19_175158_edited9_downsized-jpg (244.15 KiB) Viewed 33404 times
