Tiger
Postby mikemeister_admin » Fri Jul 17, 2009 4:52 am
I think I have the colors right.  I left the background a little darker to put the focus on the tiger.  Too much do you think?
2008-01-30_142354_02_edited8_downsized-jpg
2008-01-30_142354_02_edited8_downsized-jpg (999 Bytes) Viewed 41145 times
Postby -default » Sat Jul 18, 2009 9:28 pm
Good job - nice detail and tones on the tiger.  Not too much at all.  Most people are distracted by the blown out foreground.
Postby ggroess » Mon Jul 20, 2009 8:59 pm
Agreed...but...can you do anything about the foreground??
Postby mikemeister_admin » Thu Jul 23, 2009 3:39 am
Do you want me to try and tone down that hot spot?
Postby ggroess » Thu Jul 23, 2009 2:36 pm
How would you handle it??
If you want to give it a try that will only help you with later images that are similar...
not required....
Postby mikemeister_admin » Fri Jul 24, 2009 4:46 am
Well Greg, I hope you are grading on the curve.  I tried two things, neither of which seemed to improve the image that much.  The first is a lizard tail.  The second was a mask.  I thought the mask was the most likely to succeed but I pulled the L curve down as much as I could but with really no improvement in the highlights.  Those pixels seem to have gone to a better place.
2008-01-30_142354_02_edited9mask_downsized-jpg
2008-01-30_142354_02_edited9mask_downsized-jpg (250.65 KiB) Viewed 41145 times
2008-01-30_142354_02_edited9lzt_downsized-jpg
2008-01-30_142354_02_edited9lzt_downsized-jpg (246.74 KiB) Viewed 41145 times
Postby ggroess » Fri Jul 24, 2009 2:18 pm
I thin k you found more of them in edit 9
Good going...
BTW some of them are seriously not there but there are some to be found...
