St Vitus' #1
I have the advantage there..I have seen it corrected multiple times...
But you should always make a habit of checking the highlights and shadows...I always try out a lizard tail just to see if there is something obvious missing...
Just flex the curve at the very beginning...If the highlights get better, reset the curves and make sure you add a lizard tail to the correction before you are totally done.
