Berkeley Drummers
Postby mikemeister_admin » Tue Jul 14, 2009 4:29 am
Greg:
My approach to this was not as simple as your solution, but I think it worked out.
Brian
2005-09-25-111823_edited5_downsized-jpg
2005-09-25-111823_edited5_downsized-jpg (999 Bytes) Viewed 25202 times
Postby ggroess » Tue Jul 14, 2009 12:57 pm
I'm not even going to ask what you did...
You hit all the marks...The faces are all in the correct "range" the shadows are black not blue and you have decent tonal range maybe a tad contrasty but the web does strange things to images...
Great Job!
Postby mikemeister_admin » Tue Jul 14, 2009 7:51 pm
As usual, I just made it harder than it had to be . . . then saw the solution and saw how simple it could be.  In general had things in reverse order, and worked by direct manipulation of the curve rather then exclusively with end points.  I'm not going to show you my curves ... too embarassing.
