dan-hat
Postby mikemeister_admin » Wed Jul 08, 2009 3:19 am
BTN, BTK ("by the book")
dan-hat_edited1_downsized-jpg
dan-hat_edited1_downsized-jpg (999 Bytes) Viewed 29584 times
Postby ggroess » Wed Jul 08, 2009 11:06 pm
hmmm kinda yellow in the tee shirt....
Postby mikemeister_admin » Thu Jul 09, 2009 2:53 am
Yeah . . . right!  So that prompts a question.  Why is the red off if I correctly used the BTN approach (an assumption, I know)?  Like I said . . . deceptively simple but does not necessarily deliver a correct result
Postby ggroess » Thu Jul 09, 2009 3:38 pm
It may have something to do with the highlight choice for the reference point, Your Alt-Click sample.  How big is your sample size in the Config area ?  If you are set to 3 X 3 pixels try the highlight again at 5X5 just to see if the sample is messing with you.
Example, if the sample size is 3X3 you get the average of 9 pixels.  If for some reason the majority of the pixels you chose are blue the correction might result in a yellow cast in the highlights.  5X5 giving you 25 pixels for the sample may even this out.
