Dan & Friend
Postby mikemeister_admin » Wed Jul 08, 2009 2:45 am
In this image I thought BTN worked well, but I wasn't satisfied with my efforts to control the shadows on the left side of Dan's faces.  So I backed out and applied PS shadows and highlights.  Unfortunately this produced some significant artifacts which were mostly fixed in Noise Ninja.
dan_and_friend_edited1_downsized-jpg
dan_and_friend_edited1_downsized-jpg (999 Bytes) Viewed 29580 times
Postby ggroess » Fri Jul 10, 2009 11:21 am
Brian I'm still trying to figure out if the problem with this image is the low res of the original or that and a combination with your correction...
Postby mikemeister_admin » Fri Jul 10, 2009 1:43 pm
Are the artifacts your primary concern, or something else?  If it is the artifacts, the S&H application must have bent the pixels too severely for the quality of the image.  I could try a less agressive application of S&H or approach the image a different way.
Postby ggroess » Fri Jul 10, 2009 2:27 pm
na...it's the redish cast which is highly reproducible on my side...
The Blinds in the background are actually a yellow tan in color...they appear too red and when I go after the image I am getting simular results...I may repost the original with more data in the image file...
