Smart Object
Postby mikemeister_admin » Fri Apr 17, 2009 10:51 pm
When I reopen a Curvemeister smart object layer, the changes I made previously are gone.  It's as if the curves themselves are not saved, because I see the image as it looked originally.
This is Curvemeister 3.0.8.
Postby ggroess » Fri Apr 17, 2009 11:01 pm
There is a yellow scroll icon in the upper right corner of the curves window.
click on it before you apply the curve to exit.
It tells CM that you are using a smart layer.  The current PS interface cannot tell CM how it is being called.  When you click the scroll you set a flag for the system to get it right.
Let me know if that does not work.
