Old Friends
Postby mikemeister_admin » Thu Apr 16, 2009 4:35 pm
They're back and this time their Tee shirts don't have a blue cast!
Image 2-later that day,more shadow detail
Postby ggroess » Thu Apr 16, 2009 6:49 pm
Awesome job...
Do I get to be picky??
Postby mikemeister_admin » Thu Apr 16, 2009 8:18 pm
Yes.I have a quibble or two with the image also.
Work Flow
1 A brightness adjustment for the faces,then a slight lift to the saturation channel.
2 Quick select of all light colored garments including  jacket folded over arm and woman in background.
3 Located cast in blue side of B channel
4 Adjust sharpness
The adjust sharpness seemed to add some texture or artifacts and a very slight magenta cast to the front of the guys' shirts.
Could bring out some shadow more detail.
Postby ggroess » Thu Apr 16, 2009 10:36 pm
Just based on your assessment...
I took your image into CMYK...You have a magenta cast...go to the magenta channel...
I opened the shadows a bit using the K channel since i was there...
I may have gone too far on the K adjustment but the magenta was easily killed...
Sharpen is bringing out some color noise that is for certain.  Maybe back off a bit or possibly a light blur in the AB channels of LAB.
Postby mikemeister_admin » Fri Apr 17, 2009 12:21 am
Copy,copy image above has some magenta removed.
