After a bit of work I've changed the image imperceptibly.The color of the drum bodies is different.The drum heads are a bit dimmer.
1 a slight lift in the shadow regions
2 establish some neutrals
3 skin pin with background layer opacity set to 30
4 sharp
Also considered a skin mask but the drumbodies were in the same range.
Berkdrummers
