Jay - Week 3 - Bad Skin Tones
Again well done...be careful with the placement in the darker shadow areas. You can get some skin tones that cross over to the magenta side of the red marker on the hue clock pretty fast. You can get away with it sometimes but often the color cast created causes the rest of the image to suffer.
The man on the right with the number 14 is a fair example of too much magenta. It is a pin placement issue. He is really the only one that you might try to improve the others look just fine.
