64 bit version 3.0.15b
Postby -default » Tue Mar 31, 2009 8:06 am
A new 64 bit beta is available (for 64 bit CS4 only):
This version fixes a problem that prevented Curvemeister from being installed if Photoshop was installed in a non-default location.  For example, if you installed Photoshop on your D drive, the installer would install Curvemeister in the corresponding folder on your C drive.
Postby mikemeister_admin » Tue Mar 31, 2009 11:56 am
-- and therefore it finally worked for me, since I always make my apps install on my D: drive! I've always considered it stupid deluxe to install *anything* on the OS's C: drive -- in the idiotically named default "Program files" folder (for what on a drive isn't a file?!) -- it bloats the drive and makes it much slower to create image-based backups.
Postby -default » Tue Mar 31, 2009 9:01 pm
Great - looks like the installer has "turned a corner" and can now install Curvemeister reasonably reliably!  Now for the *real* bugs!
