Several people have reported an error -8 when installing version 3.0.14. No one has reported installing it successfully, so I begin to suspect that this release is a dud. My apologies.
Please install the previous beta version 3.0.13b located here:
This version of the installer may require that you browse manually to your filter folder, if you installed CS4 in a different folder than the default.
If you have been able to install v3.0.14, please let me know as this will help me to isolate the problem.
Version 3.0.13b is once again the official beta version
Hi Mark,
This problem has affected several other people, and I recommend that you install the previous beta version 3.0.13b located here:
