CS6 64bit
Jon
Postby Jon » Fri Jun 15, 2012 1:25 pm
Curvemeister, version 3.4.1 won't install in Photoshop cs6 (64bit) using the updater in Curvermeister in the windows start menu.  Even the last version won't install and I finally gave up -- then I tried installing the newest version and it says that it is incompatible with the 64bit version of CS6 and it is the 64 bit version.  Even trying to download the full version on the Curvemeister site says an error has occurred and won't let me download the full version.    Any suggestions??
Postby ggroess » Fri Jun 15, 2012 3:00 pm
Well I run the latest version with cs6 and 64 bits just fine so lets see if we can get you downloaded and installed.
try this link and make sure to download the 64 bit version if you need it.
http://www.curvemeister.com/forum/index.php?action=downloads
go to the customer downloads area and select the correct version
Lets keep going until we solve this...
Jon
Postby Jon » Fri Jun 15, 2012 5:05 pm
The download link you sent worked perfectly.  CS6 showed up and installed with no problems and all is well . . . Thanks SO much -- very appreciated!!
Postby ggroess » Fri Jun 15, 2012 5:47 pm
glad to help...keep asking questions...we'll keep trying to help!
Postby -default » Sat Jun 16, 2012 3:40 am
Hi Jon,
Glad everything is OK - FYI I made an error with the 64 bit installer image.  The tail end of the file was being lost during the upload process.  This has been fixed now, so the normal update procedure should work as well for people who have not yet upgraded.
Users browsing this forum: No registered users and 82 guests
