Temple Fugures - Thomas
Postby mikemeister_admin » Sat Feb 28, 2009 6:08 pm
Here is a try. Adjusted mask in PSE. Increase stauration a bit,
Thomas
Postby ggroess » Sun Mar 01, 2009 3:30 am
Thomas,
Again a slight color cast...are you using the numbers on the hue clock to help you find a neutral??  You can only get so close visually.  I set my hue clock to LAB values so that i just have to find a spot that is easily identifiable.
Other than that you have done a fine job on the image...
Postby mikemeister_admin » Sun Mar 01, 2009 10:16 am
Normally I try to use the hue clocks. In this example I missed it. Thought picture looked nice but a miss. Here is new try.
Thomas
Postby mikemeister_admin » Sun Mar 01, 2009 10:35 am
Increased saturation a bit more.
Thomas
Postby ggroess » Sun Mar 01, 2009 4:03 pm
Better again...
Just keep an eye on the hue clock going forward...It is always helpful...
Users browsing this forum: No registered users and 57 guests
