Curvemeister_3-3.0.8 and cs3 with Vista with hp64 bits
j2e4a8n
Postby j2e4a8n » Tue Feb 17, 2009 3:36 pm
Hi,
I have a problem going on your site at the download page. It appens when I click on a link to post an email. My screen start to flash randomly so I cant see nothing.
I went there because I cant find the folder of the swatches and pins in Vista. The file structure is so complicated . Why the hell did they do that? Anyway, I started curvemeidster in photoshop cs3 started curvemeister filter but the pins could not be found.
Thanks for your attention.
Jean Pierre j2e4a8n
j2e4a8n
Postby j2e4a8n » Tue Feb 17, 2009 4:31 pm
I found the folders in
C:Documents and SettingsAll UsersApplication DataCurvemeister.comCurvemeister_3
I still dont know for the flashing stuff...
Postby -default » Tue Feb 17, 2009 7:05 pm
Bonjour Jean Pierre,
I'm glad you were able to find the files yourself!
I haven't seen the flashing yet.  Which browser are you using?
Yes, the file handling in Vista has caused problems for a number of people.  I will email you a link to the beta download page.  If you still would like to install the newest version, 3.0.13, has some fixes involving the pin files in Vista.
j2e4a8n
Postby j2e4a8n » Mon Feb 23, 2009 5:19 pm
Yes I would.
JP
Postby -default » Wed Feb 25, 2009 5:56 am
Hi Jean-Pierre,
I emailed you a link to the download area on Feb 17th.  I'll send another copy of the email using a different account.  If you don't receive it within a few minutes, please email me at mike@curvemeister.com and I'll reply directly.
j2e4a8n
Postby j2e4a8n » Wed Feb 25, 2009 3:26 pm
I am a bit afraid.  My version work and I cand get the pins by hand if needed.
I have CS3 suite  photoshop version 10.0.1 and I think it is 32 bits could it be?
Jean
Postby -default » Thu Feb 26, 2009 12:54 am
Yes, your version is 32 bits.  There is absolutely no requirement to upgrade your copy of Curvemeister, but there are some good features you might like in version 10.0.13.
I hope you will share some more of your paintings with us, and perhaps how you use your paint pins with them.
j2e4a8n
Postby j2e4a8n » Thu Feb 26, 2009 7:12 pm
Do you mean this one CM_64_3.0.13b.zip?
Postby -default » Thu Feb 26, 2009 11:31 pm
I made a mistake - the latest 32 bit version is 3.0.12.  3.0.13 is for 64 bit only.
j2e4a8n
Postby j2e4a8n » Sun Mar 01, 2009 3:23 pm
i INSTALLED IT.
i MADE THE 2 TEST: oK
wHERE ARE THE EXE FILES?
wHER ARE THE PIN FILES?
oOPS KEEBOARD
It does not find the pins file either.
Is there a special support page for this on this forum?
Regards.
JPD
Users browsing this forum: No registered users and 70 guests
