Enhancement request
Postby ggroess » Sun Feb 15, 2009 8:37 pm
Since you have the covers off CM this month....
Could you allow some more adjust ability in the Mask Blur...
Sort of like the saturation slider but with Blur on the mask edges?
Postby -default » Sat Feb 28, 2009 9:34 pm
Hmmm - not a bad idea at all.  I'll see how hard it would be to add this.  BTW, the parameters for the blur are in the registry, so you could change the presets if you'd like to play around.
The keys are located in HKEY_CURRENT_USERSoftwareCurvemeister.comCurves 3, and the parameters are named BlurLight, BlurMedium, and BlurWide, with the blur radius in pixels in the upper 16 bits of the value.
Current values are:
BlurLight = 0x10000 = 1 pixel radius
BlurMedium = 0x20000 = 2 pixel radius
BlurWide = 0x100000 = 16 pixel radius
