Did a try on B&W for this picture.
1) From Picture corrected in CM taking the red mask in CM and load it it as new layer in PSE and save picture.
2) Took original version and adjusted neutral, black and white point in PSE. Used the Convert to B&W tool in PSE and adjusted to my liking.
Which version do you prefer?
Thomas
Darkening sky - B&W- Thomas
overall the tonality and richness of the image is nice...
The mask Blur issue is shown in the screen shot...
One thing you can do is edit the mask using the paintbrush if the blur mask commands do not do it for you. just paint on the mask layer with a soft brush and set the opacity of the brush to say 50%.
