My attempt at example 1, Followed hints.
Greg how does one invert a curve in CM?
Gary
Example 1 Week 4 Contrast pinning- Gary
Which Curve??
On the mask??
On the mask you can use the mouse. Place the mouse on the edge of the curve window and it will turn into a double headed arrow like a smiley face. you then left click and drag the mouse left or right and the curve will rotate about the center axis. Keep going until you pass the vertical it is then considered inverted.
On the mask??
