garyslake
Not sure if mine is any better but I will tell everyone...
You should attempt this image especially in LAB. There is a lot of color information in here..almost every color could use a contrast boost type separation to broaden the range in the image.
I have posted my ACV file but I also made a layer copy and applied it back using soft light as the layer style and reduced the opacity until I was satisfied with the haze in the hills.
This might be a good CMYK candidate as well...
Greg!
Loaded the acv file. You have set quite som points in the center of the Lab, a and b curves, in a narrow area and adjusted them. Do not quite understand how you placed them and why exactly that adjustments? Assume on a higher level. Only learned that if curves horisontal you will get grey area, or?
Thomas
Thomas
In this particular image the colors live in a fairly narrow band near the center of the A and B channels. The idea is to put control points "Contrast Pins" on the curve and separate them vertically. The A channel in this image needs less help than the B channel.
Each point is addressing a separate color issue..Some may be useless but they are added for control and to keep the adjustment from spreading across the entire curve.
If I rotate the curve to horizontal I get muted colors.
If I rotate them to the vertical I get saturated colors.
If I take two points on the curve in the yellow range for instance...see shot attached...and I separate them vertically the "local color" gets more variation and saturation.
To do this: 1) select the first point with the mouse and then 2) hold down the Ctrl key and select the second point. You will have created a "contrast pin" manually and you can rotate them using the side frame of the curve or you can move them around together to change the color balance a bit.
Play around and see what can happen. If you are in the A channel and the Reds get to vibrant you can mute then a bit this way as well...
