WinterSeaScape
Postby mikemeister_admin » Fri Feb 06, 2009 2:29 pm
A generic winter scene.I liked the shed but I was rushed for time.Hint,roof of shed is a green shingling common to older commercial buildings here.
GregM
Postby ggroess » Fri Feb 06, 2009 2:38 pm
Noise in the red and blue channels...But I gave it a fair run....
Postby mikemeister_admin » Fri Feb 06, 2009 4:21 pm
Yes quite an interesting image, especially with the blue snow areas!  Does anybody feel we should get rid of them?
I fed it through NeatImage, FocusMagic before CM - then to give it a little sparkle I added 4 pixels of Local Auto-Levels at about 50%.
Compared to Greg's the noise has virtually disappeared from the sky thanks to NeatImage
Postby mikemeister_admin » Fri Feb 06, 2009 10:10 pm
This was my first take .GregM
Seen expanded on this site the sky falls apart.PSE noise reduction and some color treatments shifted the texture of the shed walls which I didn't like.
kessi
Postby kessi » Tue Mar 10, 2009 4:29 am
Just practising my new skills.
I'm not sure how blue the sky really would be, but I liked the vividness.
Used Lab to work on it by first setting highlights, shadow and neutral; then contrast pin and manipulated the b channel.
Please don't hesitate to correct me. I'm still waaay at the bottom of the ladder of experience.
kessi
Postby ggroess » Tue Mar 10, 2009 12:54 pm
Hey Kessi!
Give the shadows a bit of Lizard Tail and see whats in there...
You are doing just fine...keep up the practice...
Postby mikemeister_admin » Wed Mar 11, 2009 8:43 pm
I made some modifications and would like to share, it's been a while since I've been here and I can't remember how to upload my image. Can anyone give me pointers on that?
Anyway I adjusted Levels for each color and the saturation a bit and then I blurred the blue channel in order to get rid of the graininess in the sky, I figured it was a compression artifact but it looks better that way. Hopefully I can figure out how to share it soon. Thanks.
Postby ggroess » Thu Mar 12, 2009 2:46 am
Everyone,
  • Please remember to re-size your images to fit under the 200kb limit per image.
    You can have up to 500kb per post but no more than 200kb per attached image.
  • If you are new to image re-sizing you can use the PS or PSE "save for web" command under the "file" menu to help you re-size the image.  You might want to keep the overall image size to 1024X1024 as upper limits for both horizontal and vertical sizes.  Just set the quality value to give you an Image that is less than 200kb.
  • You might want to look into a freeware printscreen program.  I use Gadwin Printscreen
http://www.gadwin.com/printscreen/ version 4.4 is free. This will help you capture screens that include the curves windows and to help us work with you on your images.
  • Hope this helps
    Postby mikemeister_admin » Thu Mar 12, 2009 6:25 pm
    Thanks a lot, I didn't see that option below. Here is the image I worked on, let me know what you think.
    Postby ggroess » Fri Mar 13, 2009 1:42 pm
    Brookrouge,
    There seems to be a blue cast over the image...
